You have to be happy with that. Sounds like it runs spot on as elevation changes. How much boost are you running and what clutching? Thanks
how's the noise ?
any chance you could get us a DB reading ?
i hear their quiet maybe the quietest kit available
but it's really hard to confirm
thanks
sorry i'm obsessed with this issue ha ha
Is there really a reason to have that boost gauge with this auto altitude compensation feature kit?
Allot are trying to stay away from cutting holes, cant see the value.
If you're going to be adjusting boost levels for the conditions then you'll need it. I plan on turning it up for big pow days and down in the spring. Taking a glance at the boost gauge when I do to make sure I have appropriate octane. If you're not gonna mess with it then it's not necessary that's why it's optional component of the kit.
Do you think there clutching is good, or is there more there?If you're going to be adjusting boost levels for the conditions then you'll need it. I plan on turning it up for big pow days and down in the spring. Taking a glance at the boost gauge when I do to make sure I have appropriate octane. If you're not gonna mess with it then it's not necessary that's why it's optional component of the kit.
Nature of the beast. I guess thats why God invented superchargers. Same thing in the Auto industry. Love turbo vehicles but you get behind the wheel of something supercharged, it is a different animal. Not saying I want a supercharged sled but no matter who builds it, takes a sec to spool that wheel. In saying that I have to think there is more left in the clutching. I also would like to try TRSs clutching.It seems good. But there is always more. I'm going to test TRS's clutching once I get some lightning weights heavy enough. Ideally I'd like a little better response from idle/off boost to WOT. Once you're making any boost and/or above 5000RPM its very quick response - just as fast if not faster than stock. But like jumping creeks and logs and stuff off idle you have to grab the brakes momentarily to get the turbo spooled and RPM's up in order to pick the skis like a stock sled can do. That may just be the nature of turbos, but I'd like to not have to do that. We also haven't had any deep snow to see how hot everything is getting and how stable RPM's are under a lot of load for sustained WOT.
Tony's clutching works! (Trs)
Like others have said
Make sure and do all the pieces
Don't half *** it ( like i did at first)
You thought you're turbo had long legs
Before! Look out kid. She keeps pulling ??
Before! Look out kid. She keeps pulling ??[/QUOTE
Whats the best way to get ahold of TRS to buy this kit?
