Good for mpi on finally fixing the problem, I can understand some frustration from customers but remember, you chose to buy from the lowest bidder when modding your sled.
iam not here to start a pissing match but mpi is the only turbo kit maker having issues & they are the only ones moving the air separator.so its pretty easy to see where the prob is,yamaha put the air separator where it was for a reason mpi moved it.I guess I am a little more patient as I have had Nytro's and Phazer's upside down and puke oil on the belt.....in fact I lost count on how many Phazer belts I oiled until I built my own roll over valve. The Viper is much better at oil loss than the Phazer was but it is still annoying to say the least. I will be buying this MPI kit as soon as it is available to the public for both my non boosted Vipers.
I guess my point here is this was not a MPI issue but a very well known Yamaha 4 stroke issue. Did the turbo make it worse? Not sure but I am sure this oil everywhere issue has been with us a very long time and I am very happy MPI has a cheap fix for it.
I wondered why you would say something like this then I realized you are building a competitor turbo to MPI turbo. Boost-it I believe? Nothing wrong with backing your vendor but please be honest about it.
Tell Neil my non radiator non boosted Viper still cools well with the scratchers down...just like an M8. For those that don't remember Neil said "Deleting the stock rad is a waste of time and money. There is no way the bulkhead cooler will make up the cooling needed for this motor."
Good luck.
Good luck.
lol this just goes to show how big of a idiot you are,yes i run a boost it kit & recommended them to people,i have also recommended mpi kits to alot of people.i also offered up a fix for the mpi issue that does the same thing as the mpi fix,stopping the oil from backfilling the air separator so how would your stock machine backfill the separator when its in the right position,oh thats right its not its only leaking oil when upsidedown witch a rov would solve.
you are the only one that bashes people for questioning your ideas,iam simply trying to help guys to get there sleds running the way they should.
you need to grow up & stop being the problem,when you have no idea what your talking about,you are just making yourself look stupid.
You can source a banjo fitting for the hose, work well and you can move it to the best angle needed...
Big thanks to Matt @ MPI for getting these out so fast! Mine showed up today. I assume the shim goes between the motor and the threaded plug? Why different sizes though? 0.1, 0.2, 0.5
Hey Matt is there that much oil coming through that line to warrant not using one. All it needs to do is drain the oil that makes it to the oil air separator correct?? Just curious or does this fix take care of the need of using a roll over valve. I would think the only time there should be a lot of oil in that line is if the sled is upside down and the motor is still running in which case oil would be still being pumped by the scavenger pump in the bottom of the engine.
