Some follow up on my mounting of Riot kit without the chain rub blocks.
1. over time I could hear the chain slap against the goofy shaped aluminum spacer just ahead of the rear 18 tooth sprocket. I took out the spacer and machined it flat to the mounting bolt. Still at times coming down steep hills feathering my brakes and chain a little loose I could hear that chain slapping.........like chains like to do.
2. A few weeks ago my weekly RIOT upgrade project was to fix that.......mitigate that as professional say.
3. pictures of my current solution, works, quiet things down, almost eliminates the constant chain snapping/flopping.
I have run it with and without the little spring tensioner, works about the same. The end of the block to the rear in front of the 18 tooth sprocket slides over the pin that in the original RIOT set up anchored the top rub block. I machined the long block with a boss riding on the chain rollers , sitting still the chain does not touch the rub block in the back, yet if the chain flops like chains do, it can't touch the aluminum spacer, too keep the chain block from sliding off the pin, the 3/16" plastic flat piece goes behind the aluminum chain case spacer fastened by the two black head sheet metal screws.
at the front the the chain block, a piece of race car plastic on the side of the block and slotted with an 8mm bolt through the kickstand mounting spring bolt keeps the front in place, this is a very light spring, again if there is chain snatch/flopping, the chain can't touch the swing arm bolt, so it hasn't blown off in 3 rides, taking it off it shows no wear..........that was that weeks project.
4. The 15 to 18 chain setup changed my gearing from what I had been running on my other TS kits. I though it was going to be tooo tall, not so, works far better............but due to the Riot kit/better Riot trackt /now heavier better springs on the shocks/ better shock dampening this combination climbs up on the snow better than any kit I have owned.
5. Last weeks plan, ditched my radiators complety to run only my heat exchanger, slimmer more agile riding postion, runs 2 degrees cooler all day, was running like a clock 184, now , 182 ? don't figure.
