Mounting gas can and bag on a 146"
Well, I guess I'm not alone in this one...I've looked at every way possible to mount the gas can and the factory semi-rigid case (originally for the MXZ) for the back and this is what I came up with. As you can see, it is possible to have it all with a 146, and I'm pretty sure the soft bag won't work. If you notice, I have 2 non-SD rubber straps across the bag in an X pattern, as a tribute to the sled's name. I hope this helps my plight, as I've gone through too many of the soft bags with torn zippers, lost several hundred dollars in parts, sno-bunjes, gloves, goggles, etc. Also, that is indeed non-SD duct tape on the buckles to keep them from backing out.
If this doesn't work, I'll be giving a thoughtful commentary on the quality and durability of the factory accessories provided by BRP.
By the way, mounting the gas can like this seems OK in this configuration. Also, I think I'll be less likely to kick the buckle undone, as I've done in the past under extreme side-to-side movements.
Wish me luck
![DSC00379.jpg DSC00379.jpg](https://www.snowest.com/forum/data/attachments/20/20483-5acc930b9799d2411b56c1971856520c.jpg?hash=WsyTC5eZ0k)
