Wow you guys had good replys while I was typing mine for the last 20 minutes. Sorry to repeat some of the same stuff!
DV
Are you a boater? Have you ever tried to get an underpowered or overloaded boat up "on step"? That is what you must do in the deep soft snow. An 800 will get up and plane out far quicker and easier than a 600 or smaller sled. Make sense? The other big thing that the bigger engine will let you do for the same reason is to go SLOWER when you have a big hole, tree,log ect... at the base of a hill. You can slow down for the obsticle, but have enough motor to be able to recover and get back up on step and still make the hill. With the smaller motor you will have to bonzia over or through things to keep your momentum up so you don't get stuck. An 800 151-163 is basically your all around workhorse of the mountians. It is not a hotrod, but what I put my wife and kids on so that they can get around! I don't care what flavor you ride, the same holds true.I have never met anyone that regrets the hp in the deep. Likewise, after a few rides and learning your blalance in the powder, you will not notice the track length. Like was said earlier, The longer track also allows you to go slower as you are learning. I am glad to see that you have decided to make the jump to a real mtn sled rather than try to mod your xfire. You will far happier and money ahead.
Tim
Floatation is important, but its not everything. I'm no good at technotalk, but basically tree riding I haven't noticed a huge advantage for HP. However when climbing or jumping in deep snow, the 800 spins the track faster. More HP = faster track spin = climbing higher and jumping bigger. Granted a properly clutched and geared 600 could maybe match or beat an 800 that was not set up properly.
All that being said, I'll really like the 600. It's been a great sled and burns less gas than the 800 for sure. Its also fun and challenging to keep up with everyone on 800's. I can usually get where the 800's go, just not always the same route.
I think your enjoyment factor will be highest if you get a sled with similar track length and HP to what your riding buddies will have. The 600 and 800 weights are so similar that I cannot tell any difference when riding them. If anything the 800 power-to-weight ratio makes it feel lighter.
If you are a new deep snow/mountain rider AND on a smaller, shorter sled its gonna be tough onyou to keep up. To keep your learning curve shorter and playing field evener (is that a word?), I'd go for the 800 151 or 159 if I were you.
Just my .02 or .03 though.
Congrats on the move to AK by the way!![]()
The m5 was a great kids sled!!! Put a 50-100lb kid on an m5 watch them go. Gets back to the power to weight ratio thing.
the sled under you doesn't matter all that much. Plus its 90 percent operator and 10 percent machine. Get a clue.
If he can afford to have a proper mountain sled then he should. I know I've tried to ride a crossfire 136/1.25 in deep snow and it is alot more challenging compared to any new mountain sled. DVarmit you wont look back on a Summit or whatever sled you choose.![]()
Take it from me. No one likes to be the last guy straggling behind the group, holding everyone up. Go rent a couple different sleds and ride with your group. You'll be buying a big enough sled to keep up. And, in the mountains the only thing wrong with a BIG sled is sometimes there's nothing challenging.
