Hello all! Well the 600 is back in the garage now with a few more problems. I just replaced the stator and for the first 20 minutes of the test ride it rode just fine. Then the bogging started. Unless I eased onto the throttle, the engine would bog like it was flooded. If you ease it to about 5000 rpm you can then mash it and the sled will respond accordingly. I have also noticed that it idles at a lower rpm (like 700) than it should.
On top of that, I just noticed that my primary clutch is not aligned with the secondary clutch. The primary is offset to the outside of the sled a noticable inch or two.
I would put money on the bogging problem being a fuel problem. I have heard that the screens on the fuel rail can get clogged as well as the screen in the fuel pump. After pouring over schematics for hours I can honestly say I cannot seem to locate any screens on the fuel rail. I have also heard that these 2003s have fuel filter. However, I cannot seem to locate a fuel filter either.
Am I just being a bonehead on this one? How do I go about locating potential fuel filters/screens and how do I check them?
- #CompleteSleadBonehead
