J
Jnorth
Finally got an opportunity to do some testing on my 120 enduro kit. Initially I thought the upper idler shaft was broken by contact with the motolink arm. I no longer believe that was the cause. I removed all shock preload and spring retainer and completely compressed the suspension so that the rubber bumper in the shock was compressed about a 1/2", essential bottomed out. At that point I still had nearly a 1/2" clearance between upper wheel and the motolink. I have photos but can't post? Additionally, there was no indication on the arm that there was ever any contact. In my case I believe other forces caused the shaft to break and we may be looking in the wrong area for a fix. When the suspension leans that puts stress on that shaft also, when stuck in a hole the only thing keeping the rails from staying in the hole while the bike is maneuver out is the rear slide joint and that upper shaft. Pulling the bike sideways out of a hole puts considerable stress on that shaft and rear joint. Of those that have had a shaft break can you see any evidence that the motolink hit the wheels?
That is interesting that on your kit, the bogeys don't make contact with the moto link. They sure do on mine. (137 Mountain). When mine broke, I am fairly positive that it was due to that contact because it was my "first ride" with the updated bogey assembly and I hadn't even got stuck yet. I did however, notice bottoming out a few times. I totally agree that the side force on that arm in normal operation are too strong for that bogey assembly and rear slider to handle in they're current design.
