I checked compression tonight and clutch side was 90 and exhaust side 95. I'm at 5550 ft in elevation. 800 155 with 900 miles, been running doggy on the top end. What should compression be at my elevation? Thanks
Its still basically the same motor as the pro. So its for sure posible.It is headed to Vickery motorsports in Denver Saturday. It would be there sooner but I-70 is closed to a large rockslide in Glenwood Canyon. I tested it in a heated garage 7 pulls wide open both plugs out. Saturday and Sunday it only pulled 78-7900 rpm. I think it's conformation when I'm only seeing around 90 psi in each cylinder. Talking with Vohk today and he said they have seen 2 other 16 Axys with smoked top ends.
Sent from my SM-G900V using Tapatalk
Your joking rightWhat??? It's basically the same motor? Are you making this up?
Your joking right
Piston are same basic specs, redesigned, cranks are diffferent they are lightweight porkchop. Cylinder is slightly different with the new exhaust valves. Ill probably put a fix kit in mine ar about 1000 miles. Ill have to see how it will work with my slp pipe and if (probably will) it need a fuel controllerMy sarcasm meter is all f'd up tonight. The motors don't have much difference other than pistons.. same cranks and rods, same cases, same cylinders, same head..
Bore stroke rod length. Im just saying the problems that the pro engine had are going to still effect the axys engine. All they did was put grooves in the pistons.Different oil pump, exhaust valves, reeds, injectors and pistons (not to mention clutching and air plenum). Pretty much the same though. If you are referring to bore and stroke then I agree.
