more power
hi, i have a 2003 polaris 800edge. it has a slp single pipe with can, 151x2in track. i just got beat by an m7 last week and he has a can and a 153x2in track. how can i add some cheap power to my sled. without spending a buttload of money. maybe changing a few things here and there. i ride around 7-8000 feet it does have some clutching done to it. it has the stock gearing and i am tacking 8100 rpm. let me know what you think. thanks
you know i am not right sure how he did we are pretty close to the same weight. i couldnt believe it either. he just has a can and mine has slp pipe and can.pretty close to the same track. i think that his sled is one of those that just run way good for some reason. we are going up again maybe on saturday and i kind of want to show him what the 800 can do if you have any tips please tell me. thanks alot.
setup
You need to give us more info on your setup... altitude... what gears.. what clutch setup... limiter straps... what rpm were you getting... everything you can think of...
800 EDGE TECH TIPS
TECH TIPS for 700 & 800 EDGE's, Free Mods & Best Bang for the Buck
I had a 2002 EDGE-X 800 that was EXTREMELY WELL dialed in for a "Stocker" 6400+ MILES RIDDEN, NEVER BURNED IT DOWN, NEVER BROKE.WALKED away from my (3) other buddy's 800's BIG TIME !!
BEST BANG FOR THE BUCK MODS
HOLTZMANN ATAAC FUEL COMPENSATOR, spot on jetting ALL the time $ 245.00 from www.holtzmannengineering.com mileage increased from 10.5 m.p.g. to approx 13 m.p.g. noticeably more responsive on bottom end and mid-range.
SLP HI-Comp heads, for use with 91 octane ($330) improved bottom end & mid-range GRUNT!!
almost FREE MODS
PRIMARY CLUTCH:
1) Check your belt to primary sheave side clearance, should be .010" to .015" w/NEW belt, mine was .070" from the factory.
2) Install a new primary clutch spring @ the start of every season. (approx $31.00)
3) Send your primary clutch out to have it balanced. Since these sleds have a bad rep for wasting the crankshafts, put a dial indicator on the crank snout (remove primary) and periodically check the run-out. 002"-.0025" is the MOST I would want to see. Made a NOTICEABLE improvement in smoothness and extends crankshaft and clutch life, they drilled 8-9 lightening holes in mine, that's how far off it was from the factory!! SLP and others charge only $35.00 for this service. Do this after you've set the belt to sheave clearance.
4) FLATLANDER SET-UP FOR 800 EDGE
a) ALMOND/red stripe SPRING (POLARIS part # 7041988)
b) 66 gram stock weights, OR
c) SLP's 68 gram MTX'S with 3 grams in the tip, plus 2 to 3 grams in the middle, slight improvement over 66's
SECONDARY
Button Secondary
1) Install a new secondary clutch spring @ the start of every season. (approx $31.00)
2) Replace the (3) little plastic wear buttons, they're approx $ 1.00 each
3) FLATLANDER SET-UP FOR 800 EDGE
a) Stock SOLID BLUE Secondary Spring
b) R-49 Helix, (POLARIS Part # 5133023)
Roller Secondary TSS-98 or TSS-04
1) Install (1) DELRIN washer under the spring cup in your secondary clutch (less than $5.00)
2) FLATLANDER SET-UP FOR 800 EDGE
a) Helix 70-42.46 duration SLP part # 50-90
b) Secondary spring 140/200 Red/Dark Blue SLP part # 50-4
The old style button clutch was faster on top end
BOTH PRIMARY & SECONDARY
1) Align your clutches (offset, center to center, and check for engine "crooked"), mine and my bud's were off!!!! You may have to shim behind the rear engine bracket(s) to get it perfect. Use thin Chevrolet style starter shims available @ Auto Parts stores under the “HELP” brand.
2) Lightly sand both primary and secondary clutches w/180 grit perpendicular to the way the belt rides and wipe down w/lacquer thinner.
3) Wash/scrub (plastic bristle brush) your BRAND NEW belt w/soap & hot water, and let dry overnight, sounds weird, but it removes the "mold release" compound that would otherwise would get smeared all over your nice clean clutches.
4) I prefer the #3211087 belt, it's a CLOSE TOLERANCE version of the #3211080
CLUTCH TOOLS, USE THE RIGHT TOOL FOR THE RIGHT JOB (pics got moved to the top of the IQ section, under "INCREASING YOUR IQ" TECH TIPS FOR 600/700/800 CFI's
TOP= POLARIS LWT Part # PS-47477 identifiable by the LWT 1 1/2" tall letters inscribed (approx .070" of built -in "kick" WHICH IS GENERALLY MORE THAN YOU WANT!!!!!!) for use with TSS-04 LIGHTWEIGHT SECONDARY ONLY (contacts the outside of the secondary)
MIDDLE= SLP part # 20-191 This tool is parallel, "straight" no built-in "kick". For use with roller secondarys fits the TSS-98 PERFECTLY, Will work with TSS-04 requires .100" setback measurement to be factored in with a stack of feeler gauges or vernier caliper.(contacts the outside of the secondary) SLP now has a new tool specific to the TSS-04 to where you don't have to jerk around with measuring .100" back, new for 2010, PART # 20-188 $49.95, TEAM also has tools specific to the TSS-98 and TSS-04
NEXT TO BOTTOM= SLP part # 20-150 Standard for "Old style" button secondary, Basically EDGE's and older Indy's. 5/8" OFFSET between backside of secondary. This tool is parallel, as in "straight", no built-in "kick" (contacts the backside of the secondary which is somewhat inaccurate as the backside of the secondary "moves" with the width adjustment on the models with externally adjustable width secondarys)
Bottom Hi -Performance Engineering Center to Center Tool, E-Z to fabricate out of a piece of Scrap Aluminum or Steel, cut-out for jackshaft is 1" Exactly, after that 11.5" c/c. After that you do NOT need the additional 1/2" diameter holes shown in the pic, only the 1" horse shoe or 1" round hole cut-out is req'd and then put some black magic marker on the edge of the tool, tap lightly on the crank snout and you'll have your mark, compare that to your 11.5" scribe mark
I've HEARD REPORTS OF SOME TOOLS NOT BEING "STRAIGHT", PROBABLY NOT A BAD IDEA TO CHECK 'EM WITH A STRAIGHT EDGE!!!!!!!
ENGINE LIMITERS
1) SLP push engine limiter MAG side ($47.95) SLP part # 23-50 (E-Z 20 minute installation, only one hole to drill into your aluminum bulkhead)
2) WMS Engine torque arm, P.T.O. side, in front of the engine. ($82.95) sold also by SLP part #23-53 (E-Z bolt-on installation, no holes to drill)
T.P.S. CHECKING & RE-SETTING PROCEDURE (easier than you think)
1) Check/reset your T.P.S. Pretty E-Z to do, build a tester for $10. Make sure you have EXACTLY 5.0 VOLTS FOR TESTING PURPOSES. Don't overlook this! Look at the how to set your T.P.S. info here on this site, all the info is there.
2) The EDGE's get set at WIDE OPEN THROTTLE, spec is 4.0-4.1 volts.
3) Move the throttle gradually from idle to full throttle and back down again while watching the needle on your analog style voltmeter as you want it to move gradually in synch with the throttle, an erratic needle reading indicates a faulty T.P.S. and replace if neccesary.
CHAINCASE and GEARS and CHAIN TENSION
1) Check your chain tension in the chain case, adjust it to where the chain will almost touch the backside of the case w/finger pressure. While you're in the chain case place a metal straight edge onto the sprockets to make sure they're EXACTLY in line. Shim with thin 1" I.D. shims available from auto cylinder head shops, used as valve spring shims. Same shims also fit onto the secondary shaft for getting the offset "dialed in"
Stock factory gearing is 25/40, change the bottom gear to (41), same 76 pitch chain still fits, less of a dog leg, acceleration improves a little, no loss in top end.
EXHAUST VALVES
1) Clean your exhaust valves AND bores, their dirtier and gummier than you think. While you're there check the bellows for small rips and tears.
2) The original exhaust valves are aluminum, which were prone to failure and severe engine damage could result. Then they went to titanium, and the latest and greatest are Stainless Steel, identifiable by the heavier weight and "relief cut outs"
3) The original exhaust bellows were blue, the latest and greatest bellows are Orange in color.
4) POLARIS part # 2202838 (order two kits, it's only enough parts for one cylinder) includes stainless valve, orange bellow, and 1 exhaust spring.
OTHER: OIL PUMP CALIBRATION, MAINTENANCE:
1) Check your oil pump calibration , mine was 38:1 stock, 55:1 to 60: 1 is better.
2) Check ski alignment, 1/8" toe out is preferred
PREFERRED by MOUNTAIN RIDERS, DEBATEABLE for FLATLANDERS
1) SLP Big Air Kit and Flo-Rites, ($42.95 + (2) X $19.95= approx $83.00) E-Z to install , I just didn't notice any difference that's all. However, they do cause a noticeable increase in intake noise, if you like your sled quiet, don't do this mod.
2) Anti-ratchet drive wheels, a real P.I.T.A. to install, (also have to send your track out to get the windows puched out and fully clipped, LELAND PERFORMANCE, Washington State) had to cut the rail tips 2 5/16", relocate cross bar and hyfax mounting holes, and from here on out have to cut the front of the hyfax's as well
WASTE OF $$$$$ I.M.O.
1) V-Force reeds, maybe slightly more responsive on it's best day, V-force's were definitely NOT worth the $258.00 and installation time!!
2) Aftermarket Silencers, even with the weight reduction, they'll slow you down and for those of you who think it's "cool" remember that next time you come across a "trail closed" sign
3) Boost bottles
Good set up
I have a 2003 Polaris 800 151” also. SLP has a clutch kit specifically for the single pipe. If you run the exhaust valve springs they recommend, an air horn kit and reeds the sled runs quite well with a single pipe in my experience. For more power get their performance edition kit. Thats $49 for the SLP air horn, $27 for the SLP EV springs, $243 for an SLP power shift clutch kit and $258 for a set of V-Force 3 reeds. As you can see I am a fan of SLP when it comes to the 2000-2005 Liberty 800 motors. PM8.
