Anybody have a bearing number for the upgraded grease-able bearing in the 13" kits? I would like to drill and tap my bearing carriers for a zert and upgrade to these bearings.
The new bearings are specula made for the MH. They are the same size as the previous year but have the grease hole in them. There is no such bearing on the market that is a not self aligning bearing that has this grease hole in it. The bearing will have to be purchased from us.<O</O
You will want to grease the bearings about every 400 miles. Do not grease them when they are new. They come 100% full of the best possible synthetic grease in them and to re grease them now would only contaminate them and is very possible that you could hydraulic the seal out of the bearing. When you do grease them you will only put 2 maybe 3 pumps in to each. Spinning the drive system while pushing the grease in is good idea but you will be impossible with all the turning parts from the track and drive system that will get in the way.<o</o
You will want to grease the bearings about every 400 miles. Do not grease them when they are new. They come 100% full of the best possible synthetic grease in them and to re grease them now would only contaminate them and is very possible that you could hydraulic the seal out of the bearing. When you do grease them you will only put 2 maybe 3 pumps in to each. Spinning the drive system while pushing the grease in is good idea but you will be impossible with all the turning parts from the track and drive system that will get in the way.<O</O
