SNAFU
My MCX 180 has always run about 9 psi boost at 6500'. This weekend the thing was a rocket and I was shocked when the boost gauge read 14 psi. I babied the thing for the rest of the day and checked things out when I got home.
The waste gate moved freely and compressed air will move the actuator so that part is working fine. I think the problem may be the TCV valve. With no power on the valve, air can flow through the valve and out the waste gate port. However, air also flows out the bleed port.
When I add a 12v source, the valve closes and boost pressure can no longer pass through. The connection between the waste gate port and bleed port are open which I think is correct. This would allow pressure in the actuator to bleed off through this port and the waste gate can close.
I think there must be something wrong with the valve that is allowing air to pass though the bleed port and waste gate port at the same time. I don't know how this valve is configured, but it may have been damaged and is not closing the bleed port when it should. This could cause higher than expected boost levels. I may be out to lunch here, but this is all I can come up with so far.
Any thoughts?
Any thoughts?
