well said, your point makes sense, so running on pump fuel at around 13-14psi, a guy can suspect around the 240hp... is that correct
second question with a turbo and 160" track with the large fuel tank, what would be a fair weight for it full of fuel
thanks again
thanks again
I think the numbers are starting to get a little optimistic here. A stock, naturally aspirated Nytro makes approx. 135 HP (depending on the dyno) at sea level which is under 14.7 psi of atmoshperic pressure. If a turbo kit was 100% efficient, which they aren't, then the motor should theoretically double its power at 14.7 pounds of boost. With the loss of efficieny taken into account, it typically takes approx. 16-17 lbs. of boost to double a motor's output. i.e. the MCX Apex kit @ 17 lbs. of boost makes approx. 310 HP. (150 HP x 2) would probably be close to 16 lbs.
According to their website, MCXpress has dynoed their Nytro kit @ 260 hp running 15 lbs of boost which is also consistent with the typical 16-17 lbs doubling the motors output (270-276 hp).
Not that it matters much it will still be kicking a$$ on all the 2-smokers.![]()
