Makeing the 800 rip
C
Clarke673
Somewhere between too dumb to quit and flat earth
I kept my sled stock for warrenty issues, now its all fair game! My sled is a 09 dragon with fox evolX ski shocks and an ez-ryde. I am ordering an auto tune for my PCV today.
The next mods in order are
High comp power addiction head
gear down
clutchman's clutching
best nitrous kit???
HRP drop and roll
z-broz a-arms
But i can't decide which is the best nitrous kit? What are you guys running? And what else should i add to that list.
High comp power addiction head Good idea... Run 100LL aviation gas... the gas at the pump is crap and you wont be able to buy anything but ethanol blend by the fall... The extra octane will allow you to run 13.51 and that in itself will give you better performance.
I've heard all the stories about leaving in the O2 sensor and running the system in "closed loop" mode full-time.... don't believe the hype... use the O2 sensor for TUNING ONLY and then remove the sensor... This info is backed up by Jim at dynotech and many others including the tech guys at DynoJet (they make the PC's..... fine to leave it in on a 4 stroke.. not on a two stroke... my 2 cents.
gear down 19-42
clutchman's clutching If you are investing money in these mods... get the Primary clutch dual plane balanced and completely gone thru... I like Indy Specialties because, IMO, they do the most thorough job CLICK HERE FOR A DESCRIPTION OF THE DIFFERENCES IN SERVICES AND WHAT HE DOES Yest there are other good services out there... but make sure you are doing an apples to apples comparison.
best nitrous kit??? Here is where you run into difficulty...the way I see it, since you are already are running the PC-5... you will only be able to run the NEW Boss system that has its own fuel supply and no piggyback module that changes the injectors...
You cant piggyback on top of a piggyback controller.
Make sure you are running EGT's with this as well... not just the AFR on the Auto Tune.
HRP drop and roll Nice kit for a conservative drop... there is no roll to it, so if you have a front cooler/exchanger.... delete it. This will give you the clearance you need for up to a 2.5" lug and 8 tooth drivers on a 2.86" pitch...much better with a stock track as well
z-broz a-arms IMO... If you want to boondock well, go with the 40".... The 43" requires longer shocks than the RMK length of 17"... I dont care what anyone says... the 43" with the stock length shock (17") will NOT give you good performance... IF you got your EVOL-X's used from a snow cross machine...get them re-valved by Carl's for the RMK spec AND have the shaft spaced for the proper extended length... if this is the case... the 43" is possible..... but I still think the 43" is best for climbers and jumpers, not hardcore boondocking...not that there are not some that boondock circles around me with the 43" wide front.
Add the ARP bolt to the PTO front motor mount or go with the 2010 mount.
Go with a high quality can like the SPG Ultra-Q or Super-Q
Make sure that you replace the Jackshaft bearing if you have over 1000 miles, check the chain tensioner, change the oil in case, add a high strength pull rope, Run NGK BPR9ES PLUGS, Better spark plug wires/boots (ask Super Dave3) Clean the exhaust valves well, run water wetter, set the oil pump, change the fuel filter, set the belt deflection and wash/scrub the belt every 3 rides and clean/scotchbrite the clutch faces every 3 as well. Add some good console air intakes...Like the Fire N Ice (console and behind the windshield and next to the gauge).
Add the SPG or FTX bumper for better frontal protection.
We will be hitting the new Pro 800 hard this season.. There is always more power to be had, hopefully it is not too hard to find...
We reintroduced our Polaris 800 head so that will be part of the package. I am working with a few pipe makers to get a good pipe.
Can't wait for Winter and to extract some hidden power from the 800.
The fox shocks i have are off my IQr, they can self adjust to 18.75". I am having them surviced shortly along with lall my zero pros in my rear suspension. I am a free rider so i have to have the 43" a-arms, already got some in line from anger management...I might go 45" not sure.
I am going to hold off on the drop and roll for a few months atleast. When i do that i am going to swap the track for a camo extreame.
I was told adjusting hte oil pump is a pain the ***... and i already have a hps can, not planning on running an aftermarket pipe. I was also looking at the boss system because i can get good deals through them.
Ohh and no turbo for me! They don't work for my type of riding, i have been talking to ripcharger though :face-icon-small-hap
I actualy want to go lower gearing, and i don't mind uying a new chaine. I want low gearing, with a topd speed of about 65 mph. Do you know what that combo would be mh? And as far as vents go, i will be getting a full hood and vent kit from mountain fit hoods.
I'm not a fan of the hood vents made with plastic frames.
DeepDiver (all sincere questions here) ...Doesn't the type of AV gas and additives depend on the location?
I trust that you are a person in the know... but there are many on here that run it no problem.
What actual properties of the formulation make the AV gas for sustained throttle operation and only for very cold operation.... additives? What kind??
I'd like to see if Sunoco or others will start offering a lower octane "RACE" gas... Say 98 or 100 octane, no ethanol and higher grade to start with.
IownU... What does Self adjust mean?
I have the EVOL-X's too... like to find out what you mean by that?
18.75 is long, even for the 43" wide front.... Plus the valving is way off for a free rider even with the rebound and comp adjustment... IMO, I'd get a revalve on them... If you think they are good now... wait till you get them in the right valving trim and length.
Those would be the correct length for a 45" wide front... on a budget, you should see if an IQR owner with a 2009/10 wants to swap you for the Stock Holz A-arms that come on the IQR from the factory.
i have had nothing but plastic frame vents from a few places...including mountain fit hoods, fni, long tracks edge and 2cool....love them...and i hav eneer had an issue, and i actually prefer the plastic over metal..but thats another subject, lol..
i would LOVE to see a lower octane race fuel put out as well, would be AWESOME...and pretty close in price to AVGASS 100LL...but in the meantime..it will be STRAIGHT AVGAS for my 975 (if i ever get it started) and the Tubro when i go that route as well...GREAT perf, and great price ;)
just my inputs for what its worth...now...back to lerking
one of the best mods I did to mine was changing the track..I have found the 5.1 track hooks really good in certain types of snow and not very good in many other types...the powerclaw or the camo extreme are both very popular...(I run the extreme)..the slp single does make a noticable difference..but you must clutch it to get the most from it..clutching makes a big difference on these sleds....
Those would be the correct length for a 45" wide front... on a budget, you should see if an IQR owner with a 2009/10 wants to swap you for the Stock Holz units..
C
From what i was told from the guy who bought hte shocks (has been king of kings at jackson) was that you don't have to have teh exact perfect length shock. He told me just to deflate the shocks when instaling them, and then pump them up once instaled till you get the desired feal for them. My shocks are DILED IN. After messing with them for half a season i can honestly say that if anyone comes near my shocks with a shrader valve, they are going to regret it!
I also do not want to run race gas because i put on 2000 or more miles a season, and the cost would be outragious! I don't want to get crazy, but the heads that were in the old 800 engines would be considered race gas heads now days. My buds old gen II nitrous sled with a stock head is like 140 pounds of compression and .005 squish, his new "race gas" engine he runs in his 08 dragon from slp has 125 pounds of compression and .006 squish.
So is anyone runing the boss nitrous set up? i could live with buying like 25 gallons of race gas and just filling the small tank when i want to use the button. And like i said, there is no way i will be turboing my sled! just does not work for me.
Hey..
thanks for shopping NAPA..!!!!
245 IS your TOTAL $$$ thanks Matt
Tell me where to send it! I need it here by like thursday if thats possible.
ops send it to
at pay pal thanks matt
sorry i don't do pay pal
thats kool.
Just send me a check..
Matt Theye
118 N. Main St.
Stewartville, MN 55976
thanks matt
ok i'll send it out right now, anyway you can still ship it today? check my reputation, i have never ****ed anyone over.
Forward Message
Today i got a Check For 225$$
Missing 20$$ from total and he wanted me to send it out before i got the check.. I am no dummy i waited till i got the check.. i am going to still wait for the rest!!
From what i was told from the guy who bought the shocks (has been king of kings at Jackson) was that you don't have to have the exact perfect length shock. He told me just to deflate the shocks when installing them, and then pump them up once installed till you get the desired feal for them.
First of all... this is all meant to try to be helpful and to discuss the topic...please do not take it in any other way.
If that is what works for you... stick with it. (sincerely)
Here are my thoughts on this for what it is worth.
Something to ponder, but definitely just IMO.
If you can't get the shock into the suspension when it is pumped up... something is wrong and the shock would be trying to overextend the suspension when you deflate to install and "pump-up".
RMSHA sleds are generally low mileage sleds that get well maintained and are checked for cracks etc. Also, their setups are very specific for the needs on a hill climb course. Most riders are not the best technicians...some are though, to be fair.
It is sometimes possible for someone selling the shocks to tell you "Everything works this way...dont worry".... when sometimes this is not the optimal setup you think you are getting.
If that is the type of riding (RMSHA) that you are doing.. then this should be the type of advice you should seek.
There are a couple of problems that can happen with too long of a shock.
1) The ball joint is over rotated when extended fully. This full extension happens a lot when you are riding the sled, anytime you go over a bump or thru the pow or climbing jumping. This binds up the steering when the front is extended, and places a lot of leverage and stress on the ball and end of the A-Arm... This leads to premature wear on the ball and socket and can cause cracks in the A-Arms.
I'm helping my neighbor with his 2010 Dragon 800..... on the stand at a his house right now. He got a set of shocks from a 2010 Assault (that swapped out to Floats). With the weight off the sled, the steering binds slightly and is difficult to turn... and the lower ball joints are maxed out. The ride height (which should be around 9"-9.5") is now on around 11".
2) With longer shocks, ride height is not correct which will give you higher steering effort and not work in harmony with the rear skid as well.
With the correct ride height AND the proper pressures/valving... the sled handles better.
As an example... An 18" extended length EVOL-X with the identical pressures and settings of a 17" Evol-X shock...the 18" shock on the same sled would have a higher ride height than the 17".
To get the ride height correct on the 18" shock..you would have to drop the pressure in the main chamber and try to compensate for a softer ride by increasing the compression setting and dropping the rebound adjutment... but the end result is different since spring forces/rates do not equate directly with compression and rebound settings... PLUS you would still have the suspension extension/binding issues whenever the front of the sled is unloaded (like when you gas the sled or go over any thing etc)... All of these get you away from ideal balance in the sled.
A wider front end uses a longer shock... a narrower front end uses a shorter shock.... unless the A-Arms are specifically made to use that shock (as in the Timbersled 38" wide front end... it uses the stock RMK length shocks)
The front and rear suspensions have to work as a system...together.
I talked with Ryan Zolinger about this at Jackson just this year, at length, as well as Max from TCP, Allen Mangum from Timbersled and Mark Holz on other occasions as well. All agreed that the correct length shock just flat works better.
Here is a quote from the HRP instructions... all the suspension mfgs that I've talked to agree with this.
HOLZ RACING PRODUCTS:
Proper front ride height is crucial to the proper performance of your rear suspension. Before initial set-up or subsequent tuning of any rear suspension component you must ensure proper front ride height. For proper measurement of the front ride height, the sled must be on level ground—ideally a cement shop floor or driveway. Front ride height can be measured at the chassis where the lower a-arm attaches. Before taking a measurement, load the front of the sled and then allow it to spring back to its neutral position. Ride height measurement should be between 9 and 9 ½ inches.
-Higher is not better. Contrary to popular belief, raising the front end of your sled more than what is specified will actually hinder the performance of your Holz rear suspension.
This would be true for the Mtn Tamer... EZ-Ride...Alpha-X...Stock...K-Mod... M-10 and others.
attachment.php
What did you do to fit the Camo Extreme 2.5?
You don't need to regear the 09. Stock comes with 19/42. In fact, I've been thinking going higher with mine. Will wait until the garbage track is replaced.
The SLP pipe does work on the 800 CFI when clutching and fuel is dialed. I lost 100-150 RPM's when going back to the stock pipe and muffler AFTER running the SLP pipe and can. Reinstalled the SLP pipe and can, the R's and throttle repsonse came right back.
I didn't believe in the pipe until after I installed the PCV and took it off for testing purposes.
A PCV should be a must for the 800 CFI. It makes for a much better running engine. Responsiveness is much better. The SLP pipe gets the most out of it as well.
Carls Cycle (proprietary) helix is another must.
Replacing the garbage track is another must.
Shocks are garbage.
Depending how fishing is in a couple weeks, will determine whether I turbo this year. However, I will be testing some different suspension and shocks along with the track and a head if I don't make enough $$.
I Agree with DD on the nitrous thing, save your money. Better gains can be had with Carls porting and ECM reflash. With this, you wouldn't need the PCV, so the porting costs would only be about $300 more.
The quality of fuel at the pump however, has hit an all time low. The negative effects of AV Gas (if true, out of my repitroir) might be better than the crap at the pump these days.
Adding oil to the gas should be done, check wiring closely for proper routing, etc. watch out for wire ties especially on the bars not chewing into hot grips, check oil lines for air. New fuel filter each season.
This sled definately needs more attention than an XP. I equate it to a really hot girlfriend that has insecurities and needs to be told how beautiful she is. Everyday.
Shocks are garbage.
You actually ride yours?:face-icon-small-hapbwahahaa..what dave said...clutching is very very important on these sleds..as is some sort of fuel control...
