Although this is great outside the box thinking... I'm not sure if the solid Hex shafts would be as rigid and resist flexing like a tubular steel driveshaft would.... especially with the kind of track tension that the PRO needs to run to keep the track from ratcheting.
Flex of the driveshaft would equal runout of the QuickDrive pulley...Run-out of the quick drive pulley would lead to short belt life.
The reason Polaris went to a hydroformed tubular splined driveshaft in 2005 was not for the minute weight savings, IMO, it was for the improved rigidity of the drive shaft.
IMO... The best solution, IF you are going to substitute a drive shaft in a 2013 PRO RMK, would be a tubular driveshaft from a 2010 RUSH, 2011-2012 RUSH/SB/RMK, or 2013 Standard RMK.... of course with the appropriate drivers.
My 2 cents.
Coffee...
After I win the Powerball tonight I will pay you $50,000 to produce shafts for all the 2013 owners who have a downed sled
Sound ok with you?
OK guys, i think this hex shaft is a good idea speaking of runout!! I just recieved a brand new 2012 shaft right out of the box. with bearings on both ends i put it in a v-block jig that i made and spun the shaft. I WAS SHOCKED THAT THE SPLINED END IS WAY OUT OF TRUE!!!
a hex shaft is can be manufactured with no runout, where is these welded and 3 piece driveshafts have loose tolerances that will not work with the belt drive!!!!
Didnt read every post so maybe it was already mentioned.
Pop out those steel inserts and make a steel shaft the same dimension as the stock aluminum.....square up the ends and fully weld the inserts.
Finding material is probably the hardest part and it would need a gusset inside in the driver area so it doesnt collapse. Nothing very difficult for someone crafty with some extra time and the tools..
