using your handlebar button to capture "freezes the stats screen" so you can use the data to aid in tuning information. It would be difficult to, in most cases, reach the BD box to activate the capture. Your push to pass button I believe can be used for this if you plug it into a different port on the harness. When you reach your trouble spot push the button and then use the captured data to help tune it out. For example you may think you are in md fueling and when you look at your data you are actually in hi.
