The mapping he chose may have been too lean for the conditions.
Well, over the weekend vinnpie and i tore into the motor.
The damage is as follows:
Toasted cylinder (small chunk taken out, hangs fingernail easily)
Stator has chunks out of it
Ignition timing pickup has chunks out of it
flywheel scratched
the photo of the top of the piston shows the light dimple
Now thinking that when the ignition timing sensor went out it threw the timing of the motor off causing detonation. Still haven't ruled out a crank seal, due to the fact that it is on the pto side, and i am going to replace them anyway.
crank feels buttery smooth.
Hopefully the ecu is okay.......
If all of this was caused by a broken pull rope, everyone should take this as a valuable lesson. If your pull rope breaks, pull it off with a 10mm socket and ride it out.
here's to hoping ill be chirping broadies by next weekend!
I could be wrong.. but that dimple is the mark to show whether or not the piston is in the correct way.
