I tore into mine tonight. This has got to be one of the worst projects of all time. What a pain in the ***! Did you manage to not trash the oil bottle?
when you put it back togeather eliminate the mag side coolant line and just loop the pto side coolant line back around to the pump. Budd
Ya thats what I'm saying. Do a closed loop right at the water pump and do not reconnect to the throttle bodies.
I have not had any running issues doing this and it makes it alot easier getting the throttle bodies off and on. Budd
When I first got my sled the oil bottle got warped from heat so it was replaced under warranty. Lucky for me they didn't use any locktite when they put the new one in so the bolts that hold it in came out really easy. I tried to remove the tank without pulling the TB's but I don't think you can do it with out destroying the tank. Pulling the TB's isn't a lot of fun but its not as bad as I thought it would be and it give you a chance to clean everything up and check your reeds. Unfortunatley I had to pull my whole motor too but now its all cleaned up and getting welded today so hopefully I can get the motor back in it tonight. If you need any help give me a call.
I would leave them on, no offense budd, just don't like a frozen or stiff throttle. and with a mesh hood or no hood theres not as much heat to keep them warm on those below zero days.
I have never had a freezing problem running non heated throttle bodies but I guess any thing is possible.
