Loosen the hose clamp that holds the air filter holder elbow. Flip the hose clamp so that you can tighten it after the hood is on.
what exactly is this doing for you when installing the hood?
Thanks,
Woody
it just lets u pull it over a bit so u can slide the filter all the way on so u can put the clam shell togather and don't push it to far then its hard to get the breather line in.make sure to get the new elbow for that aswell because if its not in and u role the sled it well make a mess. i have pdi 7 turbos and have had the hoods off a ton. pain in the *** at first but once u do it a couple of times 5min max.the biggest pain is the 2 torx under the sport bumper.
