M1000 primary weights, what everyone is running.
1
10000ft
New member
M1000 primary weights, what everyone is running. I’m running D&D magna force magnetic weights maxed at 97 grams. Running 10- 12lbs of boost and having hard time keeping RPM’s down, changed primary spring few times, currently running purple CPC. (160/270lbs). At 12 boost lbs I run 7800-7900 rpm.
I think I’m going to increase primary weights to bring down RPM, what is everyone running. Looking at trying CPC adjustable weights since they go up to 110 grams. Secondary is a CPC torsion red/white spring, third hole and 38/48 helix.
What are the best turbo primary weights?
Thanks
I think OVS is suggesting a 4 post clutch just for that reason. You can load them up more. Eric at Racinstation on the forum sells them for around 500.00 I think. Then all you would need is one more of the weights you already have. Talk with OVS, they can point you in the right direction.
Thanks
I run the magna force weights as well the 86 t0 102 set at 91 10 lbs 7600 ish rpm
