Got the Diamond drive back together and went out today. Sled normally run on 87 octane tried 91 no change still bogs the same. Unplugged the throttle switch still bogged.
Had to restart it several times as it would just idle down and die. Barometric tube is clear. Last but not least pulled on starter cord and it would not retract must have busted the spring. I'm thinking I have a canidate for a little TNT!!!!
Going to try removing the attitude bog next and trying the suggestion of raising the fuel pressure up. I have it at 45 psi at 2000 rpm at 8000' at 9500'-10000' it is 41 psi at 2000 rpm.
Anybody running a 1000 with SLP exhaust and a pressure reg. only? If so what pressure are you running?
