M1000 cylinders
Sleddinhunter
Artic Cat Polaris Klim FXR
I’m pretty sure of the answer but a company just sent me a couple of replated cylinders and they both have some small pits near the exhaust port and in between the intake and exhaust ports. I’m thinking this is not a good replate job. Someone at the company said it’s perfectly normal and won’t hurt anything. Just want to know what you all think if I should send them back as I haven’t sent the core’s in and go with someone else. I’ll try to attach photos.
IMO that is beyond the natural porous nature of Nikasil plating. Either the aluminum has porosity or it was a bad re-weld. If they will give you a written warranty on that cylinder then run it I guess.
It wasn’t millennium. But I did see they say minor porosity is ok. The company that did mine told me the exact same thing as millennium say’s though. Wouldn’t surprise me if they out sourced the re-plating. From what I’ve seen is the tiny hole’s fill with oil and just lubricates the rings. In some ways it seems logical but honestly I can’t say I trust it. But if they will warranty them if there is failure in those spots then maybe I will run them.
I’m pretty sure of the answer but a company just sent me a couple of replated cylinders and they both have some small pits near the exhaust port and in between the intake and exhaust ports. I’m thinking this is not a good replate job. Someone 192.168.100.1 192.168.1.1 at the company said it’s perfectly normal and won’t hurt anything. Just want to know what you all think if I should send them back as I haven’t sent the core’s in and go with someone else. I’ll try to attach photos.
where can I find like those
Ive heard numerous horror stories from power seal, and if thats who did the plating it looks better than most (and im not saying thats a good plating job) they let go out the door!
Millennium or US chrome are your best bets. You get what you pay for.
