Ya, I’m pretty shook up.
Dear Mr. Idaho Potato head aka IDspud,I value his lol more than a hater opinion cuz I know exactly what he meant.
Number one complaint I hear from other brand riders trying our sleds on the hill is how the hell do you keep the skis down.
Lol in no way invalidates an opinion.
Beats being a prick.
i cant argue that one bit. luckily it was out of a heated shop/trailer 95% of the time. we also had a jumper made so we could fire the fuel pump with a 9v battery to build pressure prior to ripping your arms off lolIf I could get an electric start to fit I would do the 1200, otherwise no. Had a 1200 turbo already. Was necessary to have a Billet recoil handle for cold starting. And a few good friends. More than a few times it took 2 of us pulling over cold to get fuel pump primed so it would fire. Once even had to lay a heat gun on motor for 10 minutes to even get it to pull over faster than 10 RPM. Converted back to 1000 and my friends called more often to go riding.
Thanks, found it on Facebook but no update after it was running. Back in 2012 Michael Sherwood took his 1200cc 400 HP turbo setup from his Lil Orange Cat M1000 and transplanted it into a brand new 2012 Proclimb 162. I bought the old chassis and put a 300 HP turbo 1000 engine back into it. He wasn't quite done when I was there but he had it on snow soon after. The build can be found here https://www.snowest.com/forum/threads/shop-and-mbms-proclimb-1200.280224/Cody Hunt built a M1000T alpha, not sure where it is now or how well it ran but it was on the snow in 2021.
Sounds like you had some fun with clutch tapers!You can`t retaper the 800cc team clutch to fit the 1000 crank. The 1000 tap is longer if I remember correct, making the offset way off. I think you would need a clutch from the newer Yami turbo 4S to make it work (King cat/Thundercat AKA Sidewinder) to make it work. They seems to have the same kinda offset as the M1000 clutch.
Thank you for the info. Will use the 1000 clutch for now. Did you ever get the one you were working on dialed in and finished? Did the D&D pipe work good?You can`t retaper the 800cc team clutch to fit the 1000 crank. The 1000 tap is longer if I remember correct, making the offset way off. I think you would need a clutch from the newer Yami turbo 4S to make it work (King cat/Thundercat AKA Sidewinder) to make it work. They seems to have the same kinda offset as the M1000 clutch.
