M10 Airwave skid in Nytro???
H
Hrt Offroad
Does anyone have an M10 skid with the Airwave shocks mounted in a Nytro? If so, does the rear arm mount into the factory drop bracket in the factory location? Pics would be great if you have them...thanks in advance
Kevin
I just picked up a 159 M10 w/live axle, front assault air shock and rear Fox coilover ($2K Canadian and never used - thanks for the lead noob)...gonna try and get it in tomorrow. I'll post results after I give it a whirl:D
Here is a pic of mine, I could not use the stock drop brackets due to the 16 wide track, I just used 3/16 aluminum for a drop bracket. I used cr mounting locations which is just right under the running boards on the stock tunnel, on the rear and a little farther forward on the the front hole. in this pic both shocks had very little air in them due to my broken air pump, it actually sits higher when fully airred up.
we want a full report on the skid when you get back.
There is a new live live axle 162 skid with 2 Legend air shocks, 28 3/4 "
c to c, and the the rails are waaaay beefier in the back than the old live axle rails, be alot tougher to break.
:beer;:beer;, AA
