Lug Height for Ski Doo
A 144 or 151 by 16 wide with a 2.25" lug height would be about max. This track came stock on the 07 Summits. If your going to get a used pull off from a 07 Summit I would recommend you don't get the Camo Lite track. Look for the Camo Powder Max from a Adrenaline. The Camo Lite came on the 07 X packages and IMHO was not a good track at all.
How Big?
You can probably get a 2.5 under it if your sled has a 9 tooth drivers, the real question is how long of a track do you want run with this big lug. Is your 600 going to be able to pull that much track in the deep stuff?
If your talking 136"x2.5", you might be ok with the right gearing and clutching, any more than that - ???????
The 05 600 has 10m tooth drivers stock. The tallest that i would recomend is the 2" track. You can put a 2.5 under it but as I recall, that is only avaliable in 3" pitch and you would then need 8 tooth x 3" pitch drivers. The 2" Camoplast track is the best for all-around riding.
I've heard with 10t that it is a tight fit for a 2". But it would be an easy switch to 9t when you are swapping the track out.
A 600x what mxz or summit? 121", 136", 144"..... the summit x's in 06 came with 10th extrovert divers with a 2.25" track.
You can fit a 2.5" camo extreme in there with 7th drivers no problem. remember the 3.0 pitch 7th is nearly the same size as a 9th 2.52" pitch driver.
I would recomend a drop and roll though if your going with the 2.5" track.
141" x2.5" would be a sweet setup on the 600.
