For the bolts I'm sending out, the proper torque for either the shock rod bolt, is about 20ft/lbs. The nyloc nut friction should be accounted for in that spec. So in general the total torque to be measured on a torque wrench should be about 25-30ft/lbs depending on how much friction the nut has once in the locking component.
The stock ski bolt tended to loosen off, regardless of the torque applied, I recommend checking that ski bolt often!
