Haha I must have missed something, where is out $500 option on the QD sleds?Another reason why I dig the standard RMK more than the PRO Right now... Choices (at least ones that cost less than $500 (wink)
I would sell the 76p chain and get yourself the 74p.
If you look on the tunnel you will see in marker 20 46. This 20-46 setup has over 1100 miles on it.
When they went to the goofy plastic slide shoe style tensioner, was when I knew I'd never run a chain case sled again. Too problematic in cold temps, if you get on the brakes too hard you push the tensioner bolt right thru the plastic or it shatters in sub-zero temps. For awhile you could install the tried and true IQR hardened steel roller but even those days have expired now.
Im running the assualt 800 144x2 compatition track. Thinking about trying this 19/46 gearing, 97% off trail and hill riding. Being a heavy guy probably 270/280lbs dressed in gear and gas on the back rack.
Any imput or thoughts on this would be good or bad i think it would beneficial. Currently running the 20/42 gears.
Anybody changing anything in the secondary clutch like spring or helix? I have a 2014 standard rmk 800 with stock secondary and helix with the team black/purple spring. I'm installing 19/46 gears tomorrow night. I'm running 10-60's in the primary with the Polaris black/green spring. Any suggestions would be great. Or should it be good to go?
Hello.
i have polaris indy 155" 550F
stock gearing is 17/42 72p. So what do you think is there any better solution when goin ~2.5-3" track?
Hello.
