Low fuel pump pressure
Great.... just dropped mine off at the dealer yesterday, couldn't even get out 100 yards from the parking lot. Getting the low fuel pressure warning and engine not getting fuel. We'll see how long it takes to get pumps if everyone's having issues.
Yep, Poo forgot to plug in a connector, it’s right behind the turbo - on boost sleds.
Which plug would this be?
Sent from my iPhone using Tapatalk Pro
Dealer did it for me, but he showed me the plug - unplugged. What he told me is that there’s a sensor for fuel related to the turbo. Guessing when the turbo spools, calls for more fuel. Without it plugged it, it would spoil.
The plug was at about the height of the turbo (or a tad lower), straight in with the cluster of wires.
Sorry, not much more help than that.
My sled still ran, but limited power prior to the fix.
My 2022 RMK Matryx was making a squeel/whine noise at idle, perhaps 40% of the time. Sled has 400km on it. No warning messages or lights on the gauge.
I'm watching this thread to see what the likely outcome is going to be. Will it leave me stranded on the hill? Will Polaris replace fuel pump for being noisy? Is it just a little annoying noise I'll have to live with?
Open ur gas cap, if its louder than its a pump otherwise its the belt.
Mine is an N/A Pro. Fuel pump is defective and Polaris is saying there are no available parts. Guess this what I get for making the switch to Poo.
I was told today that my pump is in stock and on its way. Question is, how many pumps are affected and how many will i swap out before theres a recall?
I think my boost tank is defective.
I burned 9.5 gallons in 23 miles today. [emoji23]
Low fuel light came on.
They’re thirsty aren’t they!! Haven’t had a day where I’ve burned less than 40L (10gal) yet and I couldn’t be happier.
I’ve noticed my fuel pump starts getting noisy when really low on fuel, that’s your last warning to top up before you run out and/or ruin your fuel pump… I honestly wonder if this is why pumps are failing, guys just running them right to empty and not listening to the screaming pump.
I never even had a chance to run mine. Sled is still in the shop, dealer says they are still "researching" the issue. I had it started in the garage for about 2 minutes before filling er' up for the break-in ride, and it died about 20yrds from the parking lot after warming up for a good while. Wouldn't even idle.
How disappointing eh???
Pol changed 2 things on the motor end, new fuel pump and high resolution ignition and one of them is failing, thats a 50% failure??
I have 67 miles total on mine, it's never been below 1/2 tank (1st ride was about 25 miles, 2nd ride the same, and 3rd was obviously 17ish) My fuel pump started making noise around 40 total miles but I thought it was belt squeal from the self adjusting clutch system.
The third ride this weekend I noticed the squeal early on but again dismissed it, until I started a big climb and the reduced power low fuel pressure warning flashed. I turned around and headed home shortly after the first time it did the reduced power due to fuel pressure. It went into reduced power mode 2 more times.
Yep, needs a fuel pump.
Sounds like more off shore garbage put on our sleds.
I'm hopeful that it's something like the rumored O-ring spitting out from the connection between the pressure regulator and the pump. That at least seems to have a solution, zip ties to hold it together is one of them I've heard. I don't like the idea of zip ties submerged in fuel all the time but for a temp fix until Polaris figures out something permanent I'm game.
What I'm afraid of is that the new pump they put in is the same thing that just failed and Polaris doesn't have a solution. Mine is at Steamboat Powersports and I will be talking with them tomorrow am, until then I can only assume what they "find wrong". I know that VOHK has "discovered" the pressure regulator deal and maybe they are all talking with Polaris on this. If need be I'll gladly have my sled taken to Kremmling to Alpine motors (VOHK) if they have a real solution, it's a short season and I'm not inclined to rely solely on Polaris to solve this issue.
Pol will be throwing good money at bad money.
Im thinking my pump will fail again.
what sound does it make when faulty? had a buddy with us on his brand new polaris (first ride on it) and it sounded like an old car with all the squealing noises it was making.
