When turbo last season, riding anywhere between 0 to 2000 ish feet. 100LL up to 13psi no det on both sleds (09 800 dragon and 07 700 dragon). In my opinion, if you are running around 7psi at low elev pure 100LL is over doing it. Loosing on throttle response... I haven't been very lucky so far tho with a bunch of problems...clutching is the biggest, tried a couple things from guys on this site but it was not working too good for me, the best so far is Silber's clutch kit but I still need to fine tune it. Looks like a straight 48 or 50 helix is the way to go for turbos so I might give it a try this year. Other problems I have had is a major bog when you want to go from idle to WOT. It takes a good 1 or 2 seconds to clear off, and im not talking about turbo lag im really talking about a fuel/air problem. Can become really tricky when you're in a tight spot!
Other problem I have had is controlling the boost. Because it's so cold here and so low in altitude I have a tendancy to over boost and on the 700 I can not bring the psi's down!! That might be a problem with the wastegate tho.
Went thru a set of reed valve and they are a pain in the *** to change...
For me the intercooler is useless, create a lag that I do not need especially because like I said it is really cold in Quebec, Canada and I normally want to ride at around 8 psi.
One a/f ratio gauge went to crap
and other than that everything went well lol...
Im by myself here so I have to do all the testing...nobody has turbos around here so I learned a LOT last year!
Be ready to spend several hours, testing, fixing, thinking about your sled lol. If you have a friend that has a turbo make him your best friend now!
Good luck
