Low elevation riding
I am going to go riding this weekend at low elevation, 2500 to 4500 feet have 09m8 hcr with twisted race kit runing straight av gas. Just wondering how much boost i should run and some attitude numbers thanx
Im in the same boat for this weekend riding around some cabins at same elevation riding an 07 m8 twisted, running straight 100ll. I was gonna run 6.5 psi at the lower and try 7.5 at the higher areas just to play it safe. I was told 6 psi was safe at 2000' on straight av with our setups. As for attitude numbers im hopin too not change anything, Its worked so far;)
is your sled already dialed in or are you wanting base numbers?
Im not sure if its the same program as 09 but on my 07 im runnin
G 1.5
Y 1.5
R 0
GB 5.5
RB 7
fuel pressure 40psi at idle
hope that helps ya..
