Lose a piston?
Out riding today on my 2018 M8000, 750 miles, and suddenly lost about 50% or more of my power. Sled still idles and can hit a weak 5800 rpms. Its struggling but got me the 9 miles out with no change to loss in power. Intake had some condensation in it but no snow ingestion. Pulled the plugs and they looked odd to me. Thoughts?
Did you scope it? I'd do a compression test for sure that'll tell you quickly whether its a mechanical issue or electrical. Plug coloring i'm not too experienced there to give a experienced guess, It don't look rich, don't look lean either,
It almost looks like rust on your plug? Could it be water getting into the intake and then getting into the cylinder?
Plugs look fine, check compression, check exhaust valves for proper operation. Check belt and clutches also.
Broken primary spring, very common
750 mile on mine and 2 primary spring toast.
speed werx H5 120-310 if you ride 5-8 or 125-340 if you ride 7k and up. no adapter cup needed. use the spring for the 15 and back cat.
