G
gman086
Yes this would be a definate issue. They work on exhaust pressure not vacuum but same idea. Pressure must build up behind the bellows to overcome the spring and then the valves open. If you have a gasket leak, no pressure build up = no valve opening. Voila!
Not exactly, the point at which they open are controlled via vacuum from the ECM controlled solenoid. You can (and even SHOULD) convert them to gas powered by blocking off the vacuum lines. Then they run soley on exhaust pressure and open sooner. Gas mileage will suffer but you'll have power sooner and less heat soak (better for us mtn riders; flatlanders are best served by staying stock). The gasket IS still critical for vacuum operation as it needs to be sealed!
Have FUN!
G MAN
