U
usmc_powerhouse
I agree with the others and that the load leveling bars won't work for your aluminum enclosed. It's a tow vehicle issue for sure. Heavier load range tires and air bags would eliminate the sway, level the vehicle and trailer, and yes aim your headlights back on the road instead of the tree tops. Air bags aren't that expensive but take some time to install them right and add a compressor if you don't want to fill them manually.
I've found the easy alternative is Timbren SES rear suspension enhancements. They work just like air bags, preventing sagging and stabilizing the load from swaying, but they require zero maintenance and are inexpensive. If installed correctly they sit off the axle when unloaded not affecting the unloaded ride at all (just like an empty air bag), then when loaded they touch the axle and add load support. They are basically an long variable compression bump stop.
I was sceptical at first but didn't want to maintain or add/remove air from air bags or spend $400+ on a set so for $120 I added Timbrens to my Ram 2500 to level it out with my sled deck. To my suprise they installed in 15 minutes and are AMAZING! Worry free load leveling and no sway, I'll have a set on every pickup I own from now on..
Check them out:
http://timbren.com/timbren-ses/
Check them out:
