limiter straps
ruffryder
anyone run with their limiter straps all the way out?
just curious as to what most people have for their setup.
Limiter Straps
I have always loosened my straps all the way because it lightens the front of the sled. It is what they said to do in the manual and it seems to work great. It does make cornering a bit harder but I have a 155 Dragon and its not made for trail racing anyway.
I like them out as much as possible. Too much ski pressure tends to plow in the powder and create a loose feel to the rear in the corners. By letting out the strap to match the aggressiveness of the ski, it lightens the front and allows the sled to power-slide through the corners.
Depends on the conditions and the sled. A combination of the entire rear skid setup is what makes the setup work. I have run it with the limiters all the way in and would still wheelie like a SOB, now I got em about halfway out and the rear of the skid pretty stiff, holds the skis on the ground pretty good while climbing, but isnt a plow to ride around on. ideally I like them as far iout as possible while still keeping reasonable ski lift. which is usually just enough tension in them with the sled sitting flat it starts to pull the front of the rails up ever so slightly.
i rode with em all the way out once.. worked great, until i was on my back!!! such is the nature of the power game.. got em pretty dang loose on my old 700 151.. hangs the skis nice and the thing is just so freaking light to blast around on, seems to help em sidehill TONS as well.
Mine are all the way out, but I'm not on a sled that has enough power to make that an issue and I'm not a big time hill climber.
well, all the way out is how I have been running, but that coupled with a stiff front track shock and a loose setup rear shock is giving me a bad approach angle in the soft stuff.
take a look at this pic.
I guess I could just soften up the front shock a bunch and maybe stiffen up the rear as well? Or it could just be the angle. I noticed that mine does look a lot steeper compared to m sleds, but then again, those seem to squite a bit of sag as well.
The skid is a KMOD skid GEN 1 skid, FYI. Thanks for everyone's help and thoughts.
