E
So about 6 weeks to get it back and with pulled threads in the case. not bad
What temperature is the engine at when you test yours Dan? I did mine at room temp "65F" and did not run it prior to testing. Maybe I should have done it with a warm engine instead?
70 degrees sat overnight
Not warmed up
To give people so,etching to hang their hat on........ ( an example )
A 2002 500 XC EDGE was dropped off because it doesn't run right.
Customer said it starts good and idles pretty good...... But it it seems really rich and has not top end speed.
One of the shop guys drove it and said it seems like it needs to be jetted down a few sizes on both pilots and mains.
I said check if it has stack jetting....... It was already down one size from stock..
I said do a leak down check
45% on the PTO and 3% on the MAG.
Np tuning in the world will fix this problem..... Yes it will run better jetted down on one cylinder.
But it's down 45% power on one cylinder.
Leak down is the best trouble shooting you can do.
Dan
So just out of curiosity, in your opinion do you think if he had done a standard compression test he would have noticed a difference as well?
Definitely the BIGGEST troll on this site - by far!! No self-control at all. Nothing he says has any value at all, and adds NOTHING worthwhile or constructive to the conversation!
Surely there is someone who might enjoy his "contributions" on another part of this forum (cat section) . . .or on another site altogether, would be best case scenario.
I have found that the "ignore" feature works VERY well to keep that little "bugger" away![]()
I have the OTC tester and have never got good numbers. 1 ride on a brand new top end and I'm getting 4% & 5%. Compression test is 128psi both cylinders though.
Prior to the first rebuild I was seeing 7% & 8%. It was running 250-300 RPM shy of my buddies 850. Oil line popped off and it was tore down. Here were the pistons:
What do people think happened to these pistons ? ........, what causes that kind of damage to pistons and rings ? I would really like to hear opinions.
If you turn the volume up, you can hear how the competition reacts to the 850 Patriot's first year out.
https://youtu.be/0SNqvFN4RnU
The 850 better start worrying about the Cat...... the Alpha is one badazz machine.
Polaris will not get good consistant performance feedback until they get their cylinder finish problem fixed.
Inconsistant cylinder finish means inconsistant piston life.....which sad to say leads to sleds that run complete different within the same exact model.
Dan
<div>I do agree, but cat is having their share of inconsistent running as well.</div><div>Figuring out all this inconsistency will benefit us consumers greatly!</div>
