Last one to post WINS a Klim Nac Pak!!!
5.00 star(s)
Once on the ground, snow can be categorized as powdery when fluffy, granular when it begins the cycle of melting and refreezing, and eventually ice once it packs down, after multiple melting and refreezing cycles, into a dense mass called snow pack. When powdery, snow moves with the wind from the location where it originally landed, forming deposits called snowdrifts which may have a depth of several meters. After attaching to hillsides, blown snow can evolve into a snow slab, which is an avalanche hazard on steep slopes. The existence of a snowpack keeps temperatures colder than they would be otherwise, as the whiteness of the snow reflects most sunlight, and the absorbed heat goes into melting the snow rather than increasing its temperature. The water equivalent of snowfall is measured to monitor how much liquid is available to flood rivers from meltwater which will occur during the upcoming spring. Snow cover can protect crops from extreme cold. If snowfall stays on the ground for a series of years uninterrupted, the snowpack develops into a mass of ice called glacier. Fresh snow absorbs sound, lowering ambient noise over a landscape because the trapped air between snowflakes attenuates vibration. These acoustic qualities quickly minimize, and reverse once a layer of freezing rain falls on top of snow cover. Walking across snowfall produces a squeaking sound at low temperatures.
The energy balance of the snowpack itself is dictated by several heat exchange processes. The snowpack absorbs solar shortwave radiation that is partially blocked by cloud cover and reflected by snow surface. A long-wave heat exchange takes place between the snowpack and its surrounding environment that includes overlying air mass, tree cover and clouds. Heat exchange takes place by convection between the snowpack and the overlaying air mass, and it is governed by the temperature gradient and wind speed. Moisture exchange between the snowpack and the overlying air mass is accompanied with latent heat transfer that is influenced by vapor pressure gradient and air wind. Rain on snow can add significant amounts of thermal energy to the snowpack. A generally insignificant heat exchange takes place by conduction between the snowpack and the ground. The small temperature change from before to after a snowfall is a result of the heat transfer between the snowpack and the air.[1]
The term snow storm can describe a heavy snowfall while a blizzard involves snow and wind, obscuring visibility. Snow shower is a term for an intermittent snowfall, while flurry is used for very light, brief snowfalls. Snow can fall more than a meter at a time during a single storm in flat areas, and meters at a time in rugged terrain, such as mountains. When snow falls in significant quantities, travel by foot, car, airplane and other means becomes highly restricted, but other methods of mobility become possible: the use of snowmobiles, snowshoes and skis. When heavy snow occurs early in the fall, significant damage occurs to trees still in leaf. Areas with significant snow each year can store the winter snow within an ice house, which can be used to cool structures during the following summer. A variation on snow has been observed on Venus, though composed of metallic compounds and occurring at a substantially higher temperature.
Extratropical cyclones can bring cold and dangerous conditions with heavy rain and snow with winds exceeding 119 km/h (74 mph),[2] (sometimes referred to as windstorms in Europe). The band of precipitation that is associated with their warm front is often extensive, forced by weak upward vertical motion of air over the frontal boundary which condenses as it cools and produces precipitation within an elongated band,[3] which is wide and stratiform, meaning falling out of nimbostratus clouds.[4] When moist air tries to dislodge an arctic air mass, overrunning snow can result within the poleward side of the elongated precipitation band. In the Northern Hemisphere, poleward is towards the North Pole, or north. Within the Southern Hemisphere, poleward is towards the South Pole, or south.
Within the cold sector, poleward and west of the cyclone center, small scale or mesoscale bands of heavy snow can occur within a cyclone's comma head pattern. The cyclone's comma head pattern is a comma-shaped area of clouds and precipitation found around mature extratropical cyclones. These snow bands typically have a width of 20 miles (32 km) to 50 miles (80 km).[5] These bands in the comma head are associated with areas of frontogenesis, or zones of strengthening temperature contrast.[6]
Southwest of extratropical cyclones, curved cyclonic flow bringing cold air across the relatively warm water bodies can lead to narrow lake-effect snow bands. Those bands bring strong localized snowfall which can be understood as follows: Large water bodies such as lakes efficiently store heat that results in significant temperature differences (larger than 13 °C or 23 °F) between the water surface and the air above.[7] Because of this temperature difference, warmth and moisture are transported upward, condensing into vertically oriented clouds (see satellite picture) which produce snow showers. The temperature decrease with height and cloud depth are directly affected by both the water temperature and the large-scale environment. The stronger the temperature decrease with height, the deeper the clouds get, and the greater the precipitation rate becomes.[8]
In mountainous areas, heavy snowfall accumulates when air is forced to ascend the mountains and squeeze out precipitation along their windward slopes, which in cold conditions, falls in the form of snow. Because of the ruggedness of terrain, forecasting the location of heavy snowfall remains a significant challenge
Snow is a type of precipitation within the Earth's atmosphere in the form of crystalline water ice, consisting of a multitude of snowflakes that fall from clouds. Since snow is composed of small ice particles, it is a granular material. It has an open and therefore soft structure, unless packed by external pressure. Snowflakes come in a variety of sizes and shapes. Types which fall in the form of a ball due to melting and refreezing, rather than a flake, are known as graupel, with ice pellets and snow grains as examples of graupel. Snowfall amount and its related liquid equivalent precipitation amount are determined using a variety of different rain gauges.
The process of precipitating snow is called snowfall. Snowfall tends to form within regions of upward motion of air around a type of low-pressure system known as an extratropical cyclone. Snow can fall poleward of their associated warm fronts and within their comma head precipitation patterns, which is called such due to its comma-like shape of the cloud and precipitation pattern around the poleward and west sides of extratropical cyclones. Where relatively warm water bodies are present, for example due to water evaporation from lakes, lake-effect snowfall becomes a concern downwind of the warm lakes within the cold cyclonic flow around the backside of extratropical cyclones. Lake-effect snowfall can be locally heavy. Thundersnow is possible within a cyclone's comma head and within lake effect precipitation bands. In mountainous areas, heavy snow is possible where upslope flow is maximized within windward sides of the terrain at elevation, if the atmosphere is cold enough.
Thats is a true statement!@!!!
That is a true statement!@!!!
Snow crystals form when tiny supercooled cloud droplets (about 10 μm in diameter) freeze. These droplets are able to remain liquid at temperatures lower than −18 °C (0 °F), because to freeze, a few molecules in the droplet need to get together by chance to form an arrangement similar to that in an ice lattice; then the droplet freezes around this "nucleus." Experiments show that this "homogeneous" nucleation of cloud droplets only occurs at temperatures lower than −35 °C (−31 °F).[10] In warmer clouds an aerosol particle or "ice nucleus" must be present in (or in contact with) the droplet to act as a nucleus. Ice nuclei are very rare compared to that cloud condensation nuclei on which liquid droplets form. Clays, desert dust and biological particles may be effective,[11] although to what extent is unclear. Artificial nuclei include particles of silver iodide and dry ice, and these are used to stimulate precipitation in cloud seeding.[12]
Once a droplet has frozen, it grows in the supersaturated environment, which is one where air is saturated with respect to ice when the temperature is below the freezing point. The droplet then grows by diffusion of water molecules in the air (vapor) onto the ice crystal surface where they are collected. Because water droplets are so much more numerous than the ice crystals due to their sheer abundance, the crystals are able to grow to hundreds of micrometers or millimeters in size at the expense of the water droplets by a process known as the Wegner-Bergeron-Findeison process. The corresponding depletion of water vapor causes the ice crystals grow at the droplets' expense. These large crystals are an efficient source of precipitation, since they fall through the atmosphere due to their mass, and may collide and stick together in clusters, or aggregates. These aggregates are snowflakes, and are usually the type of ice particle that falls to the ground.[13] Guinness World Records list the world’s largest snowflakes as those of January 1887 at Fort Keogh, Montana; allegedly one measured 38 cm (15 in) wide.[14] Although the ice is clear, scattering of light by the crystal facets and hollows/imperfections mean that the crystals often appear white in color due to diffuse reflection of the whole spectrum of light by the small ice particles.[15]
The shape of the snowflake is determined broadly by the temperature and humidity at which it is formed.[13] The most common snow particles are visibly irregular. Planar crystals (thin and flat) grow in air between 0 °C (32 °F) and −3 °C (27 °F). Between −3 °C (27 °F) and −8 °C (18 °F), the crystals will form needles or hollow columns or prisms (long thin pencil-like shapes). From −8 °C (18 °F) to −22 °C (−8 °F) the shape reverts back to plate-like, often with branched or dendritic features. At temperatures below −22 °C (−8 °F), the crystal development becomes column-like, although many more complex growth patterns also form such as side-planes, bullet-rosettes and also planar types depending on the conditions and ice nuclei.[16][17][18] If a crystal has started forming in a column growth regime, at around −5 °C (23 °F), and then falls into the warmer plate-like regime, then plate or dendritic crystals sprout at the end of the column, producing so called "capped columns."[13]
A snowflake consists of roughly 1018 water molecules, which are added to its core at different rates and in different patterns, depending on the changing temperature and humidity within the atmosphere that the snowflake falls through on its way to the ground. As a result, it is extremely difficult to encounter two identical snowflakes.[19][20] Initial attempts to find identical snowflakes by photographing thousands their images under a microscope from 1885 onward by Wilson Alwyn Bentley found the wide variety of snowflakes we know about today.[21] It is more likely that two snowflakes could become virtually identical if their environments were similar enough. Matching snow crystals were discovered in Wisconsin in 1988. The crystals were not flakes in the usual sense but rather hollow hexagonal prisms.[22]
Types of snow can be designated by the shape of the flakes, the rate of accumulation, and the way the snow collects on the ground. Types which fall in the form of a ball due to melting and refreezing cycles, rather than a flake, are known as graupel, with ice pellets and snow pellets as types of graupel associated with wintry precipitation.[23][24] Once on the ground, snow can be categorized as powdery when fluffy, granular when it begins the cycle of melting and refreezing, and eventually ice once it packs down into a dense drift after multiple melting and refreezing cycles. When powdery, snow drifts with the wind from the location where it originally fell,[25] forming deposits with a depth of several meters in isolated locations.[26] Snow fences are constructed in order to help control snow drifting in the vicinity of roads, to improve highway safety.[27] After attaching to hillsides, blown snow can evolve into a snow slab, which is an avalanche hazard on steep slopes. A frozen equivalent of dew known as hoar frost forms on a snow pack when winds are light and there is ample low-level moisture over the snow pack.[28]
Snowfall's intensity is determined by visibility. When the visibility is over 1 kilometer (0.62 mi), snow is considered light. Moderate snow describes snowfall with visibility restrictions between 0.5 and 1 km. Heavy snowfall describes conditions when visibility is less than 0.5 km.[29] Steady snows of significant intensity are often referred to as "snowstorms".[30] When snow is of variable intensity and short duration, it is described as a "snow shower".[31] The term snow flurry is used to describe the lightest form of a snow shower.[32]
A blizzard is a weather condition involving snow which has varying definitions in different parts of the world. In the United States, a blizzard is occurring when two conditions are met for a period of three hours or more: A sustained wind or frequent gusts to 35 miles per hour (56 km/h), and sufficient snow in the air to reduce visibility to less than 0.4 kilometers (0.25 mi).[33] In Canada and the United Kingdom, the criteria are similar.[34][35] While heavy snowfall often occurs during blizzard conditions, falling snow is not a requirement, as blowing snow can create a ground blizzard.[36]
