If you have an older sled then 07, the voltage regulator just regulates AC current. So you can`t connect tho the wires going from that one.
Are you sure about this? I had a look at the service manual, looked like this red wire supplies power to the fuel pump and servo motor which are DC. The three wires look to be the same setup as the new style.
I read in another post that the Koso guage has a rectified built in so it can run off AC anyway, can anybody confirm this?
I'm getting intermintent startup on my Koso and i connected it to the accessory plug on the steering column loop. It probably starts 4 out of 5 times. it also doesn't like to always give me a ready - sometimes it gives some weird number like 97R or something like that.
Is my location OK for connection? Any other comments?
WHen it does work it seems to work fine and give accurate numbers as well.
