Bm fabrications I think they are the best.
No one makes higher quality bumpers, period.Bm fabrications I think they are the best.
We would recommend the ski shocks adding around 3/4" or so of preload to the coils. They come incredible soft and cause the nose to ride very low. This does allow the sled to roll front to back more on the center shock but the overall balance for day to day operation seems a bit off.I hope someone can come up with some good mountain riding baseline for the Velocity shock set up for my 2.75 165 khaos. I have my sled set up exactly as the owners manual specifies but just off the feel in the garage I’m guessing it’s not even going to be close seems pretty soft with a lot of sag inthe front and rear sitting in the middle of the stroke with me on it
Okay........
So I ordered the 210 rear spring, for those guys who are running the 210 rear spring, what's a good setting to start with???
Yours didn't come with the cool shock tool in the tool box?For those guys who have run these shocks, how bad do the adjustment knobs on the skid shocks freeze up and load with snow/ice? I know my WE clickers were terrible to adjust when this happened.
Appears to be a double ended socket for each knob. I bet it works great.View attachment 360843
That was straight up 3d printed...[emoji28]Okay????? That came with your sled or did someone make that on a 3D printer for you ???
Sent it
Have carl’s cycle put fox internals and good oil in them.
They become more consistent.
From what I have come across thus far, from others (no seat time) is that it really depends on rider weight. If you're a bigger guy then the RTS spring is a must, obviously it stiffer but you also have more weight on it.Curious for those of you that replaced the rear track shock spring with a heavier spring and left the FTS alone...... did you notice an immediate increase in ski pressure? I would think adding a stiffer spring would in essence increase RTS preload weighting the ski’s. Wondering if you do a RTS spring that you also need to change FTs to keep it balanced
