Center driver.. this is not about them, but man they make me angry! No point, no help and destroys the track. No issue with climbing or ratcheting on my 16, but the centet og the track shows damage!Have never been able to get my track aligned properly to my satisfaction. If it is parallel with the rails it rubs on one of the drop brackets. The center driver is always just inside the windows laterally. Just chalked it up to manufacturing tolerances or lack thereof. So have just run a compromise of perfect alignment. May have to evaluate my drivers as mentioned above.
There are more than one tolerance issues as jigs age. We have seen a few.
1)Bulkhead to tunnel alignment. We have to live with this one. You can machine a 1.25”ODx.120” thick spacer and install one on each side of the rear torque arm between the drop bracket. I’ve done a lot of them.
2) Driver positions on the driveshaft generally aren’t centered. It will need to disassembled and corrected. Easy fix if know someone with a press.
3) Rear suspension torque arm chassis and rail mount tubes aren’t centered on the assemblies. These can also be trued, it takes time and pactience. Sleeve spacers and tube trimming is in order.
Some sleds have all these stacked on top each other.
There is a lot of free horsepower to be had blueprinting your chassis, from proper engine/clutch alignment to the rear idler wheels. Eliminating as much rolling resistance as possible.
Those of us that are anal about it, fix them.
