Hi Performance EngineeringHold the phone...I could use a $20.00 filter for my sons 09 700. Where to get those?
Can't you just cut the bad filter out of the line and replace it with a new filter and use hose clamps to secure it? $90 for a filter that I would like to replace after every season seems steep.
Has anyone replaced the filter on the pro yet? I was sizing it up today and noticed that there is a small allen bolt with a clamp that holds the hose into the fuel rail. However, the bolt is right behind the guard that is riveted to the clutch guard and there is hardly any access to it. Anyone have a trick to get this out?
Need to move the belt guard out of the way. 5mm allen fits the bolt, it is secured with blue loctite, A special Fuel line disconnect tool is needed to remove from the tank outlet.
What do you disconnect to move the guard out of the way? Just the two bolts on the front of it? I only need to move it enough to be able to get the allen wrench on there. I already have the tool from when I changed the filter on my assault last year.
with the amount of miles a sled gets in its entire lifetime, unless you get crap in your tank or crappy fuel, can't see it ever needing replacing. i change fuel filters on cars and trucks that have over 100,000 miles on them and are still working fine all the time. so if poo says they need changed yearly they are just trying to make money by selling you a $100+filter...
