Tensioner
I made a new one using a spring for turbo manifold tension, pretty strong tension when compressed I think it will work ,I let all the air out and the chain remains tight! Still need to cut a kerf for the spring to set into and use a longer bolt with two narrow nuts to adjust spring tension,, but you guys get the Idea! Why make it complicated?? if I had more time I was going to use a broken Polaris Ice scratcher mounted to the side plate and tension spring down?
