A 9 PSI difference? How can this be?
Small intercooler and lots of boost.
Just to be sure. I'm not referring to a stock sled.
I'm only concerned about a sled with big chute turbo etc...
I guess another question here would be. Why are the darn charge temps so damn high on these 4 stroke 1100's. Are they higher than my M1000? Is it just because they are trying to get to 20+psi of boost?
The guy that figures out the right turbo, IC, controller combination to get these to pull from top to bottom without adding 3k worth of parts and 100lbs of gizmos and gadgets will be winner.
IMO, no one has it right yet. I know that will ruffle a few feathers, but honestly we aren't there yet.
Thunder
Modern 4 strokes run HOT. I know on the 4 stroke dirt bikes. The head pipe will be glowing red hot in the matter of 1 min of idle time. (In the dark). You won't see a 2 stroke do that.
Did anyone have a Super Chute clutched well enough that it would take 60-120 seconds of full power?
Unless you have alot of time, money and the ability to write maps for the ecu i would stay away from trying to take a round wheel make it square and try to make it round again.
I think some people just get hung up on the fact that they've spent over 20,000$ on a sled so it has to be good!!! And they will defend a mediocre sled to the end because they have spent so much on it. It's not about leaving "good enough" alone. It's about addressing real problems with these sleds. And heat is one of the many. No need for people to get all defensive because they spent so much money. If it doesn't work good, it doesn't work good! There is always room for improvement. It's not taking a round wheel making it square and starting over. It's about making a bias tire a radial, it's about improving on a design to make it as close to perfect as you can. So you can be truly proud of your $20,000+ spent.
So your saying "it doesn't work, so buy something else that does"
I think that is what a lot of guys are doing. Dumping the 1100's and looking at ANYTHING other than that, just because it isn't performing as they liked. It is going to take some big money, time and ability to make it right. I know for a fact I am not going to be Arctic Cat's test dummy, or any other aftermarket companies test dummy to make it right. But I know we have a lot of guys/gals on here that are pretty darn sharp, with some deeper pockets that can make this thing run. It's just getting people thinking differently rather than thinking this is the square hole, and this is the square peg for it. Your right we might need to look at fitting a round peg in a square hole.
Thunder
Arctic thunder. Your welcome to ride my sled. Your welcome to take it on a long pull as well.
Snowmow, Don't you own a big chute? Have you ridden it yet?
