i have a 08 m1000 snopro 162
i just got it and it has a slp can, y pipe,alot of venting ,aftermarket secondary, fox floats,newer seat, bar risers,gauge cage, ecu update
thats all the mods as far as i can tell
i was wondering if i can ditch the hood intake and keep the stock air box with a k&n filter with a pre filter over it it has lots of vents and im ordering a big hood vent so im not to worried about hot air under the hood
wondering if i can run that without a fuel controler and lose a few pounds and not have to worry about the powder bog
also i took the sled out last weekend for the first time and i noticed that the belt makes a bit of a squeak when going down a steep hill i inspected it and it seems to be in good shape mite be rubbing the pan slightly under the primary ?
and i noticed it has a bit of sag in the suspension i weigh 260 so im assuming it was set up for a guy 100 punds lighter
