Installed zbroz 36. I have a question about it
I installed a 36 zbroz kit on my 18 axys. I was told that It will ride like crap unless I move the front skid down to the lower hole. On my 18 I see I dont have that option unless I drill it out. I was also told if I drill it out and drop it to the lower hole that I'll need a anti stab kit. I did notice the track is not fully sitting on the ground in the front because of this change with the a-arms. What have you guys done before? Do i need to drill out the lower hole and install a anti stab kit? I leave for Togwotee in 5 days and dont want this trip to suck.
Definitely don't want to do that! What shocks/springs do you have up front?
With the skid left in the stock location the plastic bumpers on the front tip of the rails are VERY worn on my 16, so i wouldnt think about dropping the skid to the lower spot without an anti stab kit.
I used your same setup and there are no issues except the Spindle interference . ( Just grind it )
I have an assualt so it has both holes .. I run it in the top hole and do have some front track clearance but every sled does . The proper way to fix it is to use the PRO spindles and everything will be OK
But to tell you the truth I see more Camber issues with the Frontend so high than any track issues ! But I'm more concerned with snow clearance
I can rip through the whoops at WOT and have no issues doing so except my old body can't keep up like it did in the 90s
If it was me, I would definitely leave it in the upper position and just ride it first. Transfer is what makes the AXYS shine. If it rides like crap on the trail but kicks *** in the deep and steep than all is good. Good luck!
