T
Turbo11T
Quality of torque wrench is not so important to hit say 50ft/lbs as it is that it will torque the same time after time. So while you may have it set at 50 if it is only hitting 48 its not as big of a deal as it is that it will torque that same 48ft/lbs 8 times in a row.
Also a caliper that will read the to the spec that your looking for can be found from www.grizzly.com for a good price. A good 4 inch dial caliper would be your best bet. The best way to check it is measure a standard such as a bore of a bearing to check it.
