Stock reeds in it so they should be the 3R. Where I had fueling issues was on the top end. Started at 12.0 WOT under boost, (10 psi) was like you hit the kill switch when it went under boost. Backed it off to 12.5 and it halfway choked out. Ended up at 13.1 or it would not run under boost. Bottom end was as strong as a stocker all the time though.
Sent from my SM-G928V using Tapatalk
I am running 60pump/40Sunocco110. At 8-9# of boost it likes 13.2-13.4 AFR. This is at 8-10,000'. With stock head, timing, and on the eth setting. O2 sensor, picture.
12 PRO.
