Finally have the sled sorted, first the o2 sensor failures (ugh) then a recent Issue a spark plug cap I replaced wore out.... Probable cause to my weird miss and leaning out like symptoms wide open, somebody had commented on another post that the a/f will read lean with unburnt fuel as it will not read the unburnt fuel into the reading, just air thus it reads lean.
I discovered why the sled was leaning out down the trail under lighter throttle conditions, as well as the issue with the det code being set off. Boost-It's mapping they recommended really didn't work well, The sled had no gauges when I bought it, it would of been doomed to melt down on the trail I'm sure,There's youtube videos of them on the sled throwing it into the det limp mode as well when climbing a chute and playing the throttle...., If you're wide open and pinned it was ok, but beyond that, not so much.
The leaning up down the trail was because there is the point where you're lightly cruising and the turbo spins up just enough that it is making some pressure and moving a bit more into the engine even at ~10% throttle. enough to lean out the sled when the boost injectors havent kicked in yet.... So the fuel box was not fueling for it with what boost it recommended. sled was leaning way out to 18:1+, I tried a few different set points for their "baro" setting which somehow uses its built in baro sensor and map sensor to figure when to add fuel?, didn't work for me! I now opted to make it run the "old fashioned way" and read only off its internal map sensor, doing so It now fuels for that slight bit of added air down the trail! Thats one problem solved. However i have found to a degree the fuel trim on the lower rpm's will affect my spooling because it then wants to run rich when I'm giving it. (no different than how boost it had it anyways).
Next since I took my knock sensor off I have no "safety" I noticed that the odd time in and out of boost it did go lean still and have some hesitation going back on the throttle, odd time I heard a softer pop. I turned on the fuel box's "accelerator pump" and that seems to have taken away that lean spot in and out of the throttle now, It got to be worse when the boost went up, It needed more fuel as the turbo was wound right out and ready to go!.
It seemed like I had 2 or 3 issues going on almost at the same time so it just was not too easy to just sort or tune.....I can only hope it treats me well now for what's left of the season (not much) spring sure is in the air now and snows been melting a bit up high.
I appreciate everybody's input on try to help getting it running again!
