So my dad decided he wanted to try sledding and I think that's awsome I'm 31 and I got my son out there for his first time this season so three generations riding together is pretty cool .... BUT my dad decided he wanted to suprise me so he bought his own sled with zero idea what he was looking for other than an 800 with a 151+ track.
So he got a 94 ( I think ) indy storm tripple 800 that was most likely a pretty hot sled in it's day. It's got HRP extensions to a 151 2" track and tripple pipes ( that have seen better days ) with "fixed" mufflers ... loudest thing I have ever heard.
So we go riding this weekend and it starts really good and we head up the trail and all seems good. We reached a play area and the thing does not pull for nothin. I jump on and it seams to run ratty off idle ( idles smooth ) , clutch grabs at around 4,000 but no hole shot, you can't make the track spin to take off for nothing, it continues to run ratty and not pull till around 6,800-7,000 and then it cleans up and pulls like a mother.
I took the sled home with me to work on it to see if I can't make this thing work better so far I've got the carbs out found them clean with 32.5 pilots 1/4 turn on the screw and 320 main ... the carbs have dial-a-jets installed in the back of the carbs as well. Jetting does not fit with the listing on the hood , it lists 35 pilots 1 1/2 on the air screws and mains of 330-340-350 for the elevation
I also found that one of the rollers in the primary seems stuck, other than that I can only tell it's a blue spring. I want to yank it off and make sure it's working right but I don't have a puller, is there a way to do it on these sleds with out a puller ? Like packing the clutch with grease then screwing in a ____ sized bolt to force it off, or am I stuck buying a puller to pop the clutch just once? My skidoo and arctic cat puller don't fit
Also I found the sled to have two CDI's on it. One is a plastic unit bolted to the oil tank and apeals to be stock but it's not hooked up. The other was stuffed over by the oil tank and apeal to be a salvage yard part and has " 91 xlt efi " writen on the bottom.
So any help, or while you at it advise you can give me then I will be more than willing to listen. If anything jumps out at you then let me in on it.
