I think there are only 2 turbos on the planet with lag
Whats lag again?
Lag would be the time from when heat starts to spool the turbine and produce compressed air to be fed to the motor :confused:
How much lag is the question? Or which one has the least noticeable lag?
"Turbocharger Kit uses VATN (variable area turbine nozzles) with ceramic ball bearings and self-contained lubrication to deliver zero turbo-lag technology."
Is that a money back guarantee?
Oh, right, thanks for clearing that up for me.
In that case, mine doesnt have that, not a bit!
Turbo is not unlike the human brain.
For some it turns on almost instantly, for most it takes a bit of time to register....for others it simply never does! I guess it kind of depends on the system.
So then what would happen with that analogy for the human brain on crack. I suppose that would be like Turbo on the NOS
I wonder what a turbo would look like if we compared it to Chuck Norris's brain
:D
Everyone seems to be bragging how they aint got no skinkin lag. The turbo builders tell you Our System Has Zero Lag, it is a bunch of poop. Unless you are making lots and lots of boost at idle or making lots of boost before you even start your motor you got lag and probably way more than most think. If you got a lack of lag you are probably running to small a turbo and are getting ripped off on top end power. Try this, pin it for a dead stop and watch your boost gauge, unless it pings your max boost so quickly you did not see the needle move you got the lag. Sleds are deceiving because of the VRT transmission and set up properly you wont notice the lag you are stuck with. The VRT loads up your engine hard and fast so you produce boost quicker but just because your sled revs up and fricks off when you pin it does not mean the lag not is there.
Whats lag again?
What?? you dont know???? OMFG!! You gotta get some! Forget Boost at Idle - Lag is the best thing going.
I can sell you some, but its patent pending so no one can copy my design OK?
I've got lag in red, blue, yellow and green, will be making some in black very soon. I can put lag in any sled you want. I guarantee all my work. top quality lag for sure. Quick turn arounds too.
Lag works really well with our chaincase porting to maximize your lag. To get the most lag possible, as us about our ski tip reduction service where we cut off your ski tips, this will help you get the best possible lag you can! Less weight too!
Call for pricing - 1-800-I LUV LAG or check out our website at www.lagracing.com
correct, and i wont argue that point, BUT
what does it matter if the lag is there and you can ride and not even notice the lag?:confused:
Hey NoSecondChances can get lag in neon green with checkered flags? I would like to add some extra lag to my '96 zrt 600. It already has some but I want to be the guy on the hill with the most lag.:cool:
