O
Oregonsledder
I just finished installing a set of Better Boards on my 2012 PRO RMK 155. I’m pleased with the result. I thought I would share my experience.
Like the instructions stated, I removed the unwanted aluminum stock running board material. I was able to leave one piece that spanned the opening, but had to remove most of the rest of the stock material so that the BB’s windows would not be obstructed by anything. Important note, be sure to only cut off what you have to, because there is not a lot of metal left for the BB’s to attach to. I used an air saw to cut the stock material and then de-burred with a 60 grit wheel on my die grinder. I also removed the powder coating from the underside of the BB’s to get the best possible adhesion.
I chose to use the Lords 406/19 adhesive along with 25 rivets per side, with steel backing washers. Preparation for the use of this adhesive is key. Have the surface clean. I used acetone to be sure there was no residual oil from my air saw. Drill your holes carefully with the riveting process in mind. You only have so much room for the riveter, either manual or air. Test fit all your rivets to insure they go in easily as you only have approximately 6 minutes of work time with the adhesive. Test your rivet gun to be sure you can get to all of the rivets before applying the glue. I put two rivets under the toe hold on the front of the BB and there is no way to get an air rivet gun in there, so be sure you have a manual tool available.
Prepare for the worst. If you have done much riveting you will know that all rivet tools, air or manual get jammed. My air riveter jammed at about the half way point on the first board! Have a backup plan because it will happen and you only have so much time.
I used a lot of C clamps to insure that if I had a rivet problem, the adhesive would still get a good and tight bond.
In conclusion... I’m pleased with the install process, and I have to say I would never install the BB’s without the adhesive. There is very little metal left around the rivets to keep the board in place. I know Fbomb and others have had success with just using rivets, but this is my story... LOL
I hope this helps someone who installs this great product.
