Both, but make sure your helper doesn't get a faceload of glue.So when replacing grips do you use anything like grip glue to slide them on or just try to use air?
I second(or 3rd, 4th, 5th. . .) the ODIs. Great grips!You could get the ODI snowmobile grips. They are a bit thicker and should work ok over the smaller diameter bar plus cork plus heater.
I agreeeasy yes, cheap no, just because Karl Kuster thought they were great for him, I suspect the masses won't end up seeing things quite that way. Love my doo's but face it, they come out with some pretty goofy ideas....
I agree
I am thinking of changing to the larger bars as well after riding the whooped out trails from west y to IP my hands still hurt 3 days later.
Yes the bar is only smaller under the grips. Actually, a standard bar without the cork insulation is almost the same diameter as the expert bars.If I go to the larger bars will all the controls fit?
